- Mar 9, 2009
- Saskatchewan!
Hey guys, well...my truck is pooched. Here is the story:
It all started about a week ago. I drove to a persons house to pick up a bench (3 minute drive). Truck started fine. Shut it off. Loaded bench. Went to start...nothing! Literally nothing. No clicking, no lights on the dash. Guages didn't move. Nothing. It was as if the battery was completely removed from the truck. I tried jiggling things, moving things, etc etc. I popped the hood and heard a relay rapidly clicking on and off (or a similiar noise) which seemed to be coming from the passenger side headlight area (a module type looking thing below the air intake and behind the headlight seemed to be the culprit. I also heard a beeping coming from the passenger side foot area (in the cab, under the dash kinda) almost seemed the the fuel shutoff thing but I couldn't reset that so that wasn't the problem. Anyways...after some fooling around it started and I was good to go. Week goes by. Driving it a total of like...200 kms and 3 hours run time probably. And its all good.
Two days ago I go to start the truck again. Nothing. Same thing. A tiny click at first maybe. Then nothing. No power to anything. Except...my scanguage light up. Weird...so after messing around and finding nothing. I get a boost...and I crank it once...doesn't start. So I shut it off...take out the key...and the truck is still cranking! Not fast but its still turning over with ignition off and key out. Weird. This only happened once but I figure it is worth mentioning. So I disconnect cables. Reconnect cables. Then it starts up just fine. Lights on and everything . I drive twenty mins...shut off truck. Do my business...go to start. Nothing. Get a boost...starts. Drive back (30 min drive maybe). Shut it off...instantly try to start it again (maybe one second delay) NOTHING. No lights no crank no clicking. The usual.
Last night. I try to start it again. The usual nothing. Except my scanguage lights up and flickers for the next like...five minutes until I unplug it. Then I try to start. The usual nothing except this time the clicking relays happen. Take out the keys....still things going crazy. So then I turn on the lights (well...turn on the knob to high) at which point the clicking stops. And then the lights on the gauge slowly light up (like the oil light, check engine light, etc) try to start. Still nothing. Not even an attempt to crank. Weird. Plug in my scanguage...lights up...but NOTHING (as in the usual nothing...no dash lights or crank or click).
I almost don't think it is a bad battery but...its just very weird.
Anyways...any help would be appreciated!
