Well I found an oil leak I had and I was right, it was at my oil pump body housing where it mates to the block.
However, I've had this whine sound and I thought it was my water pump. After removing the fan, shroud, and serpentine belt I started the engine and low and behold the whine is coming from the camshaft sprocket. It does appear there is a small amount of fluid coming from behind the cam pulley but not enough to leak yet so while I'm there I'm going to replace it.
My question is: Is my cam bearing bad? Please tell me no!
Could it be making that sound from a bad seal?
Thanks, I'll post up some pics when I remove the timing belt and pulleys.
Allen
Allen
