Oil filter
  • Thread starter Thread starter irishblessing
  • Start date Start date
irishblessing
Guest
I got my oil changed today and they put on a Pennzoil Pz19 filter and its significantly smaller than anything if ever put on it anyone ever use this filter
Sent from DROID
I usually use motorcraft or try too thanks for the info
Sent from my SGH-T959 using Tapatalk
If you don't like it go back and ask for the correct one.
Sent from the tower under my desk...
Small filter equals less flow and plugging quicker. It probably wont hurt anything but I dont like when stuff like that happens. They probably put on the cheapest filter they could find. I would have more peace of mind if I knew the proper one was on it. There are too cheap not to change it. The small filter seems to be a trend these days. A lot of cars now have oil filters smaller than what you would find on a 20hp briggs engine. I know they are engineered correctly but I still dont like it.. But I am a heavy equipment tech. I am used to filters 8,10 inches is diameter and about a foot long.. Ones that will break your foot if you drop them on it..:icon_thumby:
The Wix compares pretty good.
50 pleats 2-5/8" high for the MC, 61 pleats and 2-6/8" tall. :icon_rofl:
But the Wix has less flutes, so its not as easy to remove....haha.
I like how they show that the Fram filter has no flutes but they just say NONE and that its a black matte finish. I think FRAM, though crappy, is probably the easiest filter to grip/remove.
I looked through it more, all the 6/8 measurements bug the heck out of me. Call it 3/4 like the rest of the world...
I had a fram on my Ranger for awhile. That rubber stuff gets weird when it is constantly soaked in oil for extended periods of time. :icon_thumby:
I wonder why ford didn't say 3/8? I mean a dumb person would probably think that 5/8 is bigger than 3/4 just because of the higher numerator.
The STP filter that I used on my Intrepid last weekend was about 3/4 of an inch shorter than the one that came off of it too... I will have to check the one that I got for the Ranger now...
AJ
Yeah I try and stick with motorcraft oil and filters if I can, its cheaper then most other oils and is recommended for ford by ford so it has to be good. I also like Napa filters.... other ones just feel so cheap in comparison.
I went back turns out they put the wrong filter on thanks for the help
