2) The 1990 & up 4.0-liter Rangers are ALWAYS equipped with the 8.8-inch 28-spline rear axle.
3) 1998-up 4x4 supercab Rangers regardless of powerplant are frequently equipped with 8.8-Inch axles
4) The FX4 Ranger was introduced in 2002 and always came with 4.10 gears only. The 31-spline Torsen 8.8-inch axle came only with the 2002 FX4 and 2003-up FX4 Level II and more recently was a separate option. The 2003-up FX4 (non-Level II) is essentially the same as the 1998-2002 Off-Road except that a regular Ford limited-slip in a regular 8.8-inch was included.
Swapping in an 8.8-inch 28-spline Ranger axle for the original 7.5-inch axle provides (according to Ford) a 35% increase in strength. But this strength increase refers to the greater strength of the gears and carrier bearings (Pinion bearings, axle bearings and axle shafts are exactly the same)
