- Aug 15, 2011
Okay, under the driver-side door, attached to the frame near the fuel pump, is a cartridge-type filter. If anyone else has one, they'll know it as a round piece (much like an oil filter) that you unscrew the bottom part off of to get to the fuel filter.
Recently, I replaced this filter... and two days ago, the housing itself cracked and left me stranded in 100-degree humid weather just 7 miles from home. So far, I haven't been able to find out what this housing itself is called. In order to replace this part, I need to know what it is. Anyone got a clue?
Basically, it has 4 connectors on top of it where the fuel lines (both from the tank and the return line) connect. It's bolted to the frame with two bolts. It seems to have a couple of valves in it (both of which are broken in this one) that seem to serve the purposes of preventing back-flow and to release air to the return line so it doesn't end up back in the main fuel line. This may have also been a large part of my problems, to begin with.
