Bronco II extended radius arm picture request....
mjonesjr
I dance with the Devil...
Forum Staff - Retired
Firefighter
Salem, IN
I am looking for a picture of the rear mounting bracket for the Superlift or any other style extended radius arms.....i need to know where they mount at on the frame.....
i actually have extended radius arms and their mounts.....i just need to know where to put them....
Whip out the measuring tape...
that is the smartest thing i have heard all day.....i have done that genious....i want to see a picture of where on the frame it mounts......
Then whats the picture for? If you had the measuring tape out you should know exactly where it goes.
if you have no picture, get lost....i don't have to explain anything to you....
Easy there I was just wondering what the problem was? No need to bring your additude from RF to here.
soooo homemade radius arm mounts are no interest to you?
no i am using the Superlift radius arm mounts.....i know they mount infront of the transmission crossmember on a Ranger, but i cant seem to figure it out for a Bronco II....are they the same mount between the two models?
well they are mechanically the same as far as I know, they use the same engine and trans.... so, yes, I would say with significant certainty that they mount in front of the trans crossmember. remember that B2's have a 94" wheelbase, so clamp it together how you think it should go (in front) and measure from front hub to rear hub. If u put it behind the trans crossmember that would be approx 6-7" different, I'm sure you would notice. It probably doesn't even look right.
i am installing them today...
