- Aug 11, 2011
Ok, So I know this probably has been posted many times before but... I have a 2001 Ranger Supercab 4x4 4.0. I wanted to get into the offroad scheme. I'm not familiar at all with lifts and things that I would need to complete the project. I do all my own work but I don't know anything about axles/gears, etc. that needs changed when doing a lift. I'm getting the 3 inch body lift kit from performance accessories with the bumper relocation brackets. Is there anything that I would need besides what's in the kit? I know the filler neck extension and that sort but as far as drive train or anything? Also what is the biggest tire I should put on my ranger with stock axles? I'm also getting a 6 inch suspension lift. I know people say you have to upgrade a lot when doing lifts but as far as that I don't know what to do.
Long Text, Read here to get to the point:
What is necessary for a 3 inch body lift?
What is necessary for a 3 inch body lift and 6 inch suspension lift?
Axle's I should use and gears?
Tips?
Use for DD and want the aggressive look and want to be able to go off road for the day and not have problems.
Again thanks for the help and I know it probably has been posted before but I suck at using the search function...
Tips?
