I have no room for anything but my 4cyl radiator without a lot of cutting I was wondering if I could use my stock one with a fan and shroud on one side and electric fans on the other and if it would cool alright. Also need driveshaft help
Stock 2.3L rad is to small. Get rid of the stock fan and shroud, use a good electric fan. Some here use a 4.0 HD radiator with good luck. However it didn't keep my engine cool. I'm running a Griffin 16"X31" radiator it took very little trimming for it to fit.I have no room for anything but my 4cyl radiator without a lot of cutting I was wondering if I could use my stock one with a fan and shroud on one side and electric fans on the other and if it would cool alright.
Good luck with that. The 16"H X 31"W in my ranger goes the frame rails to the top of the core support. Whit the filler cap sticking up past the top of the core support 3/4". The radiator in my 96 Bronco is 21" H X 31.5"W.Well I might just get a radiator out of my bronco 302 and make it fit
yea i moved mine forward with the toyota rad. and i can fit a mechanical fan in. however u have to switch to serpentine system or u have to get just a two or one groove crank pulley depending on if u have P/S or not. i don't have power steering so i'm gonna have to wait for my new 1 groove crank to come in from summit then i'll take pics with the mech fan on. however i'll get those numbers for the rad and pics tomorrow. also on the alternator my 91 originaly had a 2.3 4cyl so i just used the alternator from my 3.0 which pluged right up and had the same mounting on the 302 as the original 302 alternator. however i did have to buy the heavy duty alternator to keep the battery from dieing every so often
I used a radiator from a 97 Ranger with a 4.0 V6 and HD cooling. I was able to cut the lower part of my core support out and move my rad foward. I am using all of the stock Explorer V8 FEAD and clutch fan. I reused my Ranger's stock 3.0 V6 fan shroud and had to cut one side of it to make it work. I am using a stock V8 Explorer upper rad hose and a stock V6 Explorer lower hose and they fit just like factory.
