1) Question, will a D35 pig come off the beam, without having to remove all the outer knuckle parts? I have done the c-clip elim mod, have SJ long arms, and 6.5" of lift.....I'm trying to minimize the tear down process for my regear, just wondering if it is possible to weezle the D35 out of there without tearing everything down.
My other thought is to just unbolt the RA nut, the axle pivot bolt, unbolt the lower coil retaining nut and unhook the brake line and ABS line...then the whole assemble comes out as a big L shaped mass....done this a few times (of course gotta un-hook the driveline too).
2) Also, does the drivers side beam have enough strength to drive on it without the pig bolted up?
Thanks
Thanks
Drive on it to work and school w/o the 3rd for a few days....maybe less than 100 miles of freeway?
