- Sep 14, 2009
- SE Michigan
OK I just picked up the ranger, mechanic did say that he load tested it and the battery was bad and to replace it as soon as I could afford one. He did charge it up though and it starts and runs fine.
So I went over to sears they had a sale going on, they load tested the battery there in front of me. They needed to know the Cold cranking amps of the old battery to dial it in to his tester we could not read the label on the batt for the amps, but I told him i thought it was around 590. So he dialed that in to the tester and it read about 460 cold cranking amps. He did say that was low and it would not hurt to buy a new battery. I do plan on buying a new one before the winter at the latest...
I asked him then if using this old battery for a while would actually damage the alternator though, and he said no, even if the battery is putting out just 20 percent lower amps than expected - this would not burn out the alternator - he said alternators fail if the diodes go bad and that the current battery would not fry it out just because it is not putting out the full cold cranking amps it was when new.
Anyone agree? Dis agree?
