daily doubler build
Same spot I mounted my controller. But in cab controls ftw. A whoooole lot easier then getting out and hooking controller up.
Did you spool the rope up under load?
Of course. Not in the pics, but I did this afternoon in the daylight.
bray pick one of these up,
That would be pretty slick. I'll keep it in mind. Thanks for the link man.
You gotta pull cable anyways (if you're not an ass and make your co-driver do it :thefinger:). Might as well plug the controller in while you're out there. Then you can spool it in from inside OR outside the cab.
for the money you cant beat it, alot easier to just leave the controller on the visor and when you need it flip the switch and go. for looking like cheepo china junk i was really suprised with it.
Lol yea like I said they look like cheap junk but work surprisingly good for the $30 I paid for mine.... All the other ones are $130+
Going to order me another one soon, but I guess I should find another winch somewhere forst
2 questions one why do you need to spool rope under load? I've never done that with cable.
And two I don't see the point of a controller you have to be inside the truck to get on the breaks anyways so In cab switches just make so much more sense. Just personal preferance I guess
You may want to unspool your cable all the way and inspect it. If you don't spool it under load, the outter wraps will sink through the inner wraps/kink the inner wraps/etc when you partially unspool it to pull yourself out of a sticky situation.
Your cable could be damaged.
Its more harmful to cable than it is to rope of you don't spool it in under load since rope won't kink, but I did it anyways.
The controller deal is total preference. Both have their benefits.
how much load? i hold it out and pull while someone else reels it in (just to get it to wrap evenly) but i know its kinked in a few places already... oh well lol its also about 10 ft shorter then it should be right now. ill get a new one soon
Warn recommends a minimum of 1000lb load while spooling.
your not always in the truck when running the winch. with the wireless i can spool it in myself i can hook to whatever im hooked to and get the slack out without being in the truck.
in other words in about 1000 situations it comes in real handy over a normal controller or being hard wired in the cab.
the wireless ones do seem much more practical to me yea but i just meant the regular controllers i dont get the point of them. i just have whoever ran the cable wait till i get the slack out lol
ah, thought you meant the wireless...all ive ever seen everybody do is run them up the hood into the window.
I make everyone run their own cable. If it's your shit, you got stuck, you run the cable.
On the contrary, I'll always check out the attachment points to make sure its adequate though. I don't trust most people, with the exception of Bray and Wirsch.
When I did mine (spool under load) like a dumbass I unspooled to far and ripped the cable off the drum. When I did to it right though, I just put truck in neutral and very lightly dragged the brakes. Had a buddy watch the drum to make sure I got a decent wrap as I went.
