- Jun 4, 2011
Morning to all.
I'm new and cannot seem to find exact thread that would answer my current problem.
I have a 1994 Ford Ranger XLT 2.3L 2WD that I love and don't want to send off to a mechanic to fix.
About a month ago I went to drive it to the DMV to register it in a new state (CT) and when I tried to start her she wouldn't quiet start. So I started fiddling around looking and decided to pull the battery on the off chance it was just not enough to push it to fire up. Battery tested good. Re-installed and still same symptoms. Then next morning jumped in and tried again but this time NO POWER when I turn the key!
Checked all wire connections to and fro the battery. Cleaned all contact point and re-tighten them. Checked all fuses with a test light and all checked out. Check the relay w/ a 9v batter (room mate's idea, he's a Elec. Engineer) and all check out fine.
On the off chance the ignition switch just wasn't telling her to turn on I changed that, only $15 at auto zone. No avail. Read around and saw a fuse link might be the issue. FYI for my truck at least thats the only fusible link and its the single wire coming off the starter solenoid on the fender wall. If you read the wire it even says Fusible Link. But check ohms through the wire and it read like .1 ohms. I suck sometimes drawing conclusions from results so confirmed w/ the EE room mate and he said that's good.
So what do I check next? I am at a lost and about ready to have her towed to a mechanic and pay $50/hr diagnosis charge.
No power when turn the key, headlight won't turn on, tail lights either. But the volt meter reads 12.38 volts everywhere I've check and it should.
HELP!
Frustrated Josh
HELP!
Frustrated Josh
