i am only doing this because someone told me to when i first joined....
(i got the truck for 800 because the guy thought it needed a new engine)
my plans:
rebuild engine(this is just to make it road ready)(this is job #1 because its loosing oil)
3" or 4" inch lift (with some re-enforced ra. and drop down brackets ( iv been told i can be really abusive with vehicles, so this is just some precautionary stuff)
dual tank it(got any info on how, click here!!!)
30~3's tire (just cuz)(re-gear to 4.11 as well)
swap in m5od when this tranny goes bad (PO. replaced it in 08 with a tranny out of a 95)(or when i get tired of it shifting right as i enter that spot in the gear were you achieve most fuel economy)
because i haven't had any trouble with the auto hubs i am gonna leave 'em alone
i think i am gonna swap in a manual t-case ( once again just cuz)
the last thing or some time in-between major projects i will remove the green film and install blue leds to match the rest of the truck....
this is when i first got it home
i guessed there was 2 or 3 quarts in the engine(it was the blackest oil in an engine that was some how still running i have ever seen(it sounded like a diesel when idling)
conclusion drain and refill with new oil
the rebuild is going to happen while im on vacation so i will just ask my trusted mechanic (neighbor) to snap a few pictures while its apart
the ignition switch needs to be replaced(i can start it with out the keys)
i dont think thats stock.....(this is for a different thread i started and said it had a trans that would go in a 95 (id'd by pit in the pan) i finally found the micro chip) its ground wire should be re-done(half bare)
this build thread will go really slow until i get a job(or 2)
about the truck
found it on cl. for $1000 offered 800 because it was running rough and the guy spent allot of money on body and stereo work, and 1,200 on paint....
my plans:
about the truck
