will these wheels work on my truck (explore on ranger)
TDS
15'' exploder rims with 31'' tires on a 2wd ranger
if its a 98 and up ive seen it done with fender trimming, if its pre 98 then no way.
i was worried about off set
If the rims look like these:
You should be fine.
I'm currently fitting a set of these wheels off a 1999 4x4 ranger to my 1994 2wd ranger.
Mine are 16x7 wheels though. I test-fitted one (bare) wheel on the front, and it is about 1 centimeter closer to the coil spring than the factory 14x6 aluminum wheels that look like these:
No binding on any components at full lock in either direction with the 1999 16x7 OEM wheels.
yeah, i have seen people do it, but like i said you will have some rubbing. i personally wouldnt do it, but it can be done.
