- Sep 23, 2007
Is anybody actually running an Autolite 2100 carb that can offer an average mpg with it for the 2.3 motor?
My truck is:
'83 2wd longbed
TK5 Tranny
7.5 Rear with 3.73's
'87 2.3 Block .030 over, decked .010, forged pistons/balanced
'83 head ported and gasket matched, decked .020
Comp Cams .420 lift hydraulic slider cam
Cannon 2bbl Intake from Esslinger
Holley 5200 from '70's Stang, manual choke, Edelbrock foam air cleaner
Cast tube header
Factory EFI fuel tank and in-tank fuel pump
Stock Duraspark dist and ignition box
Emissions - ha ha ha, that's funny
This motor is much snappier than the stock one, it pulls almost any hill at highway speeds in 5th no problem while the old stock engine with 1bbl needed to drop into third and struggled. It runs like a bear but I'm still lacking some torque below 3000 RPM.
Trying to decide if I want to get an Trans-Dapt adapter plate and run a 1.02 or 1.08 venturi 2100 carb ($30 plus some fab time) or if I should just get a cam gear ($100 plus some install time) to bring down the power band with the 5200. I have multiple carbs of each type so their cost isn't a factor.
Last tank running the 5200 I actually broke 20mpg - 20.3mpg to be exact, and according to my air/fuel meter I could probably go one jet size leaner up here at altitude with no problems and gain a little more.
Obviously with the cost of fuel I do not want to drop economy a bunch. Looking for real-world experiences from other members who run the 2100. Some guy a while back said he was getting 25mpg but I can't locate the post...............
My truck is:
'83 2wd longbed
TK5 Tranny
Cast tube header
