31x10.5x15 on stock rim
86MUDRCJ
Sheridan, CA
Will they rub? I just neeed to run them for awhile till I get save up enough money.
They will only rub if you hit any bumps. With a little lift, you'll never have a problem. Is this for street or dirt?
Seeing as he is already lifted 4" they should clear fine. You should leave them on there. It will look sweet
well i meant rub on the inside of the frame when I turn. but it looks like i will do that.
they'll be fine....31x10.5 on a stock wheel
it doesnt rub anywhere, but my sway bars are out
It wont rub on your frame, but will rub on your front sway bar and may (depending on leaf condition) rub in the back wheel wells... At stock height. Any lift should easily clear 31s in the back.
If I take the front sway bar off will it drive a lot different?
i didnt notice a difference up front, it may be a little smoother. i dont have shocks out back, so it was really bouncy.
You'll get more body roll in corners without the sway bar in the front... But you will also get better articulation off road. As long as you drive relatively slow (drive your truck like a truck) then all should be fine.
I dont run a front sway bar, and I have no problems with it. (pulled it 'cause my 31x10.50s rubbed.)
i'm gonna have to be extra careful, y'all know i'm always out there racing my b2, that old 2.9 will take down a mustang!!
I drive pretty slow.unless its in a striaght line.lol but if I can smooth out the front that'd be great cuz its pretty stiff. Do you guys know of a pretty good shock to run to make street drigving aot smoother.
HAHAHAHAHAHAHAHAHAHAHAHA:icon_rofl::icon_rofl:
I got a mustang..... So put your money where you mouth is :D
