fully rebuilt automatic transmission wont engage any gears
Abe
10+ Year Member
I have a 98 Ford ranger 2WD 4 cylinder SOHC 8 spark plug engine I took the AT out my self and had it fully rebuilt I put it back in and bolted it in and then the crank wouldn't rotate to put the TC bolts on flexplate so I loosened the bolts to the transmission and it slid back about a half inch then I was able to slide the TC in all the way bolted it back and crank spins freely then I proceed and hook every think up and start it and it runs everything sounds normal but when I put it in drive or reverse I dont feel it engage and the tires don't move at all. Is it possible i fried the pcm by unplugging the tranny electrical with out disconnecting the battery. I dont think it has anything to do with the TC not being set in all the way at first what could it possibly be? The AT is a 4R44E please contact me if I didnt give enough information. Thanks ranger station
Few????
Did you force the trans to bolt to the engine after rebuild?
If so, you could of damaged the pump, hence no engagement
Did you fill the torque converter itself and then the trans?
If not, you coulda fried the converter before it got filled via the trans pump.
I don't think it would have anythin to do with not disconnectin the battery, but then again, I haven't messed with any of the computer controlled trannys either.:icon_twisted:
As far as tightening the bell housing to then engine It fit together quite easily the TC just needed slid back a eighth of an inch so I couldn't see that breaking anything internally the TC was already filled and then i put ATF in AT then started it up and it won't engage at all if I put it in neutral I can spin Tue drive shaft easily by hand and it locks in park. Thanks for getting back so soon
After starting the truck did you check the fluid level?
the trans will suck the pan dry to fill the internals
also you are using mercon V (5) right?
Yea I did I need to get more the specs said 3 quarts but dipstick was still dry so I added another quart I'm.not sure how much I need in it but dipstick was still dry after 1 gallon. Shouldn't it still engage tho
on a rebuilt trans is about 9qts. that includes the 2 for the converter.
add 2 more then check it.
3qts is just for the pan.
Hey thanks a lot for the info. But would the AT just not do anything with not enough fluid I think I should of noticed something when putting it in gear do u think it just might be the fluid if that were it that'd be awesome
If its low enough on fluid, you will not have any engagement.
