Rear axle of 95 ranger??????
Your door tag should have an axle code that you can use to find out the type and gearing using the link that Chance posted.
For example, my rear axle code is 84. This means that my truck has a 7.5 rear end geared at 3.45 and if it was a 4x4, the front would also be 3.45.
two wheel drive - 7.5"
four wheel drive - 8.8"
I disagree. I have seen 4x4 trucks with 7.5 rear ends.
The kind with a differential in the middle instead of off to the side.
ya look at the sticker on the inside of the driver's door.. my 93 XLT 4x4 4.0L has an 8.8 L/S..
Depends on the engine, anything with a 4.0L will have an 8.8, all 4cyl and most 3.0L trucks use the 7.5.
Featured Ranger Based Vehicle
