Introduction
Ford Ranger Torsion Bar & Rear Spring Identification Guide:
This guide helps you identify Ford Ranger torsion bars and rear spring part numbers from 1983–2011 using vehicle certification labels, stamped codes, and torsion bar diameters. Learn how to read front torsion bar codes (RH/LH), rear spring codes, and sticker or stamping information to ensure the correct parts for your Ranger’s suspension setup.
Whether you’re performing maintenance, swapping torsion bars, or upgrading your suspension, understanding these codes will help you get the right fit and maintain proper ride height and handling. Detailed charts and photos illustrate each code for easy identification.
Ford Ranger Torsion Bar Code / Part # Identification
Torsion Bar Code / Part # Identification - Vehicle Certification Label
(Vehicle Certification label on driver’s door)
Ford Ranger spring codes are listed as a 2-part code. The first part identifies the front spring/torsion bar code. The second part identifies the rear spring code.
Front Torsion Bar Codes
(RH = Passenger Side / LH = Driver Side)
  • 1 – F67A-5B326-FA (RH)
  • 1 – F67A-5B327-FA (LH)
  • 1 – F67Z-5B326-FA (RH)
  • 1 – F67Z-5B326-FB (LH)
  • B – F57A-5B326-BC (RH)
  • B – F57A-5B327-BC (LH)
  • B – F57Z-5B326-A (RH)
  • B – F57Z-5B327-A (LH)
  • F – F57A-5B326-FC (RH)
  • F – F57A-5B327-FC (LH)
Rear Spring Codes
  • 3 – 4L54-5560-DA (Leaf)
  • 33 – 4L54-5560-DA (leaf)
  • C – 3L54-5560-PB (Leaf)
  • CC – 4L54-5560-GA (leaf)
  • K – 4L54-5560-EZ (Leaf)
  • KK – 4L54-5560-EA (leaf)
Torsion Bar Sticker / Stamping:
The torsion bars have a sticker on them
And are stamped on the end. This is a ‘F’ code torsion bar
Torsion Bars – Measure The Diameter:
(Torsion bar code / approximate bar diameter)
1 / 1.09 inch (strongest)
B / 1.06 inch (mid level)
F / 1.03 inch (weakest)
More Help
Don’t forget to check out our 4×4 Suspension Forum
Related Articles
Cranking Your Torsion Bars
ProComp Torsion Key Lift
2008-2011 Ford Ranger ‘Pre-Key’ Modification
All About Torsion Key Lifts For Your ’98-’11 Range
1998–2011 Ford Ranger IFS Suspension Modification Guide
Removal & Installation of Torsion Bar & Key
Remove Torsion Bar Without Special Tool
About The Author
