Joeshark
Hey Guys,
Had to replace the piece you see in the photo, can't recall the name, sorry. It was broken & leaking.
Either way, attached to it was the temp sensor as well & that got broken upon removal.
I bought a new piece from Ford direct. Everything installed, but temp gauge in the floor, no movement :/.
Worked fine the day before, with old temp sensor.
I have bought a new aftermarket unit to try from autozone, to try and see if possibly the Ford unit is faulty?
Any other thoughts, ideas, tips to try?
P. S. I bled the system as best I could. Should be pretty good.
Sent from my SM-N950U using Tapatalk
