- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
When you tighten the plenium...finger tighten the 6 bolts, then torque to 7ftlbs. Then go back and tighten to 18ftlbs.Im thinking about getting another new set of plenum gaskets and pressure test my old injector and clean them and throw them back in just to see if tjat changes anything
I started with the two middle bolts, then went back passenger, front driver, front passenger, back driver.
Personally id try changing the MAP first...it would have to be a MASSIVE plenium leak to get the ecm to dump that much fuel...and it would likely idle higher then hell and show other vaccum leak symptoms. Your fuel pressure being a bit low could mean the injectors arent closing totally...but its not that low.
If the computer sees a reading of 0 from the MAP its going to think youre pulling the guts out of it and dump fuel
