Rebuild or salvage yard
Donnphilpot00
Forum Member
Hopewell va
3.0 V6
2 inch body lift
So my engine has a bad compression issue so I'm looking for advice would it cheaper to go to the salvage yard for a "new" motor or rebuild. It's a 95 ranger with a 3.0l in it 2wd.
A junkyard motor will always be cheaper than a full rebuild. That's assuming your compression issue is due to worn cylinders/rings and not head related.
But a junkyard motor is also a gamble. They usually will offer a small warranty of like 30-60 days and allow you to exchange for another one if the first one blows up during that time, but that's usually the best you'll get. Whereas a engine builder or reman company will usually offer a much better warranty of 1-3 years parts and labor.
Those warranties vary wildly from place to place so you have to do some research on who does what in your area.
Yeah I was going to do the rebuild myself so that will save on labor and it's about 400$ in parts... I can't seem to find a motor from a junk yard any lower then around 600.
look over your junkyard motor good too if you go that route, I went to replace a 4.3 in a S-blazer and the 1st engine I got had bad crank bearings & journals, when I took it back they said “oh yeah, that engine had a bad (cracked) oil pan so we put a better one on it”. Its a lot faster to just swap out engines but you dont know the history of what you’re putting back in.
Part's don't make a rebuild. A worn engine needs machine work you can't buy parts for that price and just stick it together. The engine needs to go to a machine shop for work you absolutely cannot do. You can buy new rings but can you hone the cylinders? If the cylinders are out can you bore them?
/\ /\ /\ Like he said.
X2
Currently in the rebuild process on my 2000 3.0.
Heads alone were $475 to get machined. Now I have the block, crank, and flywheel in the shop as well waiting to get worked on.
Probably going to spend around 8-$900 in total just to get components machined.
Still have to buy rings, bolts, seals, timing chain, etc...
Needless to say, a complete rebuild adds up quickly.
X3. It was about $1200 total to do my 2.3 L4 a few years ago. I completely disassembled the engine myself, then paid a machine shop for hot dip, inspection, bore, grind crank, inspect rods, source & install pistons. They also ground the valve seats and replaced valve guides, the rest of the head was OK. I bought the rest of the parts and assembled myself. Yours will be more due to two more cylinders, two heads, etc.
Side note, I bought my parts from all over scouring for the best deals instead of buying them through the machine shop I had worked with. I spent a lot of time searching for parts, waiting for them to arrive, being held up because I was missing a part, etc. all to save about $100. If I could do it over I would have just bought the parts from the machine shop and had everything at once, and kept some more money local. I figured I would save more but not in this case, your mileage may vary.
