I have a 2000 Ranger with a 3.0 flex fuel engine and a 4R44E transmission. I had DTCs P0715 and P1901, both having to do with the Turbine input shaft speed sensor. I took it to a shop to have the sensor replaced and do a rebuild while they were in there. I got word from the mechanic this past Friday that they have finished the rebuild and the transmission is installed again but that the engine immediately dies when putting the transmission into drive. I desperately need my truck back. I’m loosing work. The mechanic seems to be at a loss at this point. He says that it’s almost like the torque converter is being commanded on. I’m just trying to help my mechanic help me. Does anyone have any ideas as to what may be causing this? I personally don’t think that it’s the PCM because prior to taking it in, I swapped the PCM with a PCM that I had recently replaced and it gave me the same codes. Any explorable ideas would be greatly appreciated.
