Pictures of Engine Bay/vacuum hookups
CRAZ28
15+ Year Member
Roberts, Wisconsin
Does anyone on here have good PICTURES of their Duraspark swap using the holley 350 carb, especially wiring, and what can be eliminated. Also what vacuum lines need to be hooked up so that this thing will run?
Start here:
http://www.broncoii.org/techpages/duraspark/index.html
I saw pics of other people's swaps, but don't know where. I never did a Ranger, but have done a few on other Fords, so my only advice is to read up on the subject and if you can't figure it out, do some basic reading on ignitions. These are great systems and rarely fail. I used to use a Motor's Manual for my wiring and any trouble shooting. For instance; if you use the round type coil that came with the original units, you will need to use a resistor in the 'run' circuit to increase the life of the coil.
All your old computer stuff goes out of the truck. (I'd like you to save it all in case someone needs the parts, and you can then get back a buck or two. We still must use the factory stuff here in California)
