- Sep 27, 2023
- Age
- 43
- Sugarcreek Ohio
- 4.0 V6
- Total Lift
- 4 inch suspension 3 inch body
- Tire Size
- 33x12.50 R15
I just recently finished my 4.0 OHV build and I’ve got a really noisy top end. It’s in a 1997 Ranger 4x4 with manual transmission. Here’s what I got in it.
99 factory non EGR engine (built it while driving the truck)
Bored .30 with new pistons
Fresh ground crank with bearings
New timing chain set
New oil pump
New aftermarket heads w/valves
410 comp cam/and recommended valve springs
Smith bros 5.550 push rods
New lifters
New rocker arms
New factory flow injectors
All new sensors up to plenum
Everything was torqued to factory spec
It started right up no issues there. Good oil pressure. No smoke. But it’s got a really noisy tapping/ticking sound. Possibly a little noisier on the drivers side. Anyone have any idea what might be causing this and how to fix it? Stuck lifter possibly?
Thanks, Zack
New oil pump
New lifters
New rocker arms
Thanks, Zack
