Highway rumble
Sdude2008
15+ Year Member
Farmington CT
3.0 V6
31x10.5x15
99 3.0 5pd 4wd 170k
I’ve done some reading and do find some references to my issue but not much feedback and most posts are pretty old. Anyway recently I’ve noticed a rumble strip type sound at highway speed 55-65ish. It doesn’t happen while driving, only if I push the clutch in and it continues if I shift into neutral and coast, clutch engaged. Shifting back into gear with gas the sound/feeling goes away. I’ve seen some references in other forums but they refer to auto trans. I generally am not in 4wd at highway speeds and it doesn’t happen at lower speeds. The clutch and pp were replaced not long ago, flywheel resurfaced and pilot bushing replaced. Also u joints replaced. I also swapped in a used rear axle not too long ago. Same ratio but LS. Any advice is appreciated. TIA
Event Coverage
TRS Merch
