- Jul 7, 2009
About 6 months ago I replaced the front bearings on my '97 Ranger (my first time doing that job). At the time I was a little concerned because I thought I had them in a bit too tight. A couple week ago the right-front bearing started making thumping and grinding sounds, especially on tight turns. So, today I got another set of bearings and went in and replaced it.
I was intending to keep it looser this time, but I just can't seem to get it right. I tried seating it at 32 lbs. and then backing the nut off to 16 lbs, but even at that torque the wheel doesn't spin even close to freely. It stops after maybe 1 revolution. If I go much looser, the rotors start to flop all over the place. I can't come close to finding a spot where the wheels spin more-or-less freely without also wobbling around.
What am I doing wrong? How freely should the wheels spin? Should I drive it around for a week and then go in and readjust once the new grease has softened up a bit? I'd really prefer not keep replacing bearings every 6 months (although I'm getting pretty quick with it!).
Thanks,
Aaron
Thanks,
Aaron
