Gas in crankcase
Your truck gets one mile per gallon...
If youre burning that much fuel thru a leaky injector you woulda had plugs soaked in fuel when you did the prime test i mentioned earlier.
Have you pulled codes by chance?u
I don’t have a code reader for it, but I have done the thing where you count the flashes of the cel. It only had codes for lean o2 sensors.
Yea😂. I was just wondering if there was a way to know if it was actually the injectors physically leaking or if something was wrong with the sensors or computer telling the injectors to always remain open.
Lean O2's actually will make the engine run rich. Since the O2's are thinking its lean...itll dump fuel to compensate.
Thats the route id follow at first. Maybe check the wireing to the sensors and replace them if they are original.
Could also be a vacuum leak or a big exhaust leak before the O2
I know its been a couple years but if anyone rereads through all this with similar problems, it turned out my ranger had a bad computer. Put a different one in and it ran fine.
And how did you track down this bad computer?
Also, how much was it and where did you find a replacement?
A guy we know who's a mechanic has a small junkyard at his house, and he had a computer he put in it. Kind of process of elimination after doing injectors, and checking fuel pressure. We realized sometimes when you slapped the front fender/ door area where the ecm is housed, it would start running good. Thats why we decided to try the computer😂
Further up in the thread ronD describes how to find out if your computer is crap or not, and how to fix it if it is.
Oh yes, I read RonD's description of the "computer repair"...good stuff.
I was just wondering if the computer (positioned low in the engine bay) was entirely rusted out and possibly unrepairable.
A neighbor having a spare is the good luck story of the day.
