Are the fuel line diameters the same? I know my earlier 1986 ranger used 5/16 fuel lines. My larger trucks with V8's use a 3/8 supply and a 5/16 return.
On the frame pump (iirc 86-88) the high pressure pump is the same from 2.9 all the way to the 7.5. You probably ok with what's stock. Test pressure and (important!) volume to be sure.
Stock pump flows around 35 gph which will not be enough for my planned 350-375hp 302. I'd rather upgrade the pump and not have to worry that it's not got enough volume.
