Fuel pressure relief valve
gw33gp
15+ Year Member
Ham Radio Operator
Costa Mesa, CA
CA - USA
Other
2004 Bronco Badlands
Vehicle
Drive
1.5"
33"
I had a post about a problem I was having when travelling long distances on Interstates. Nothing was resolved and I didn't do any diagnostics because it is running very well on shorter trips.
I decide today to check out a few things to see if I could find any issues. I decided to start with fuel pressure. I found a Shrader valve on the rear of the right fuel rail. Its part of what is called the fuel pressure relieve valve in my Ford Service Manual. I attach my fuel pressure tester to it and turned the ignition switch to 'on' without starting it. The pressure would go up to about 50 psi and immediately drop to 0. I checked for leaks and tightened the connection more to make sure it was not leaking. I still got the same results. I cycled it several times with the same results. Then I started the engine and it ran very bad with misfiring. I then removed the fuel pressure tester and fired it up again. It immediately fired up and ran perfectly.
I don't know what this fuel pressure relief valve is supposed to do. It looks like it is just there to relieve pressure by pressing in on the Shader valve when work is to be done on the fuel system. I see no way for it to release fuel pressure any other way. There is no return line like there would be on a fuel pressure regulator. I am baffled why it ran so bad when I had the fuel pressure tester on it. I forgot to look at the pressure when it was misfiring at idle. I was so startled that I forgot the important part of the diagnostic. If I have time later, I may try that again.
I am seeking any information as to why it would do that.
OK, I spent a little more time on my Ranger. This time I spent a little more time pumping up pressure by cycling the ignition switch more times. I got the pressure up to around 60 before it dropped back to 0. I have a fairly long hose for my pressure gauge, and I think it was not getting filled the first time I ran my test keeping the fuel pressure to low.
When I fired it up this time it ran a little rough briefly then smoothed out fairly quick with the gauge connected. The pressure went up to a steady 65 psi. When I just the engine off, the pressure immediately dropped to 0 again.
I can't think of anything else other than the one-way valve in the fuel pump that would cause the fuel pressure to drop that fast. If the Fuel Pulse Damper was broken, I would have a serious external leak (which I don't have) or fuel getting into the vacuum system causing a rich condition (which I don't have). If you know of anything else that would cause it, I would like to hear about it.
I don't see any Motorcraft fuel pumps and don't know if they ever made them. Does anyone know what brand the OEM pump is? If not any, recommendation of a good brand?
Motorcraft does make fuel pumps, and believe they are OEM.
I thought I read that Motorcraft pumps are now made in china...which may affect quality. Bosch makes fuel pumps, which are considered better quality.
I'm not familiar with 2002 rangers, but kinda surprised you don't have a fuel return line. When I googled 2002 ranger fuel pressure regulator, they do pop up.
Generally the causes for fuel pressure dropping to 0 are:
Fuel Pump internal check valve failure.
Fuel Pressure Regulator failure.
Leaky fuel injector(s), but doubt it because of how quickly it fuel pressure drops to zero.
You could try attaching your fuel pressure gauge to the fuel line that goes to your fuel filter (from the tank). This would require an adapter, as the connection is different from the schrader valve. This would eliminate the FPR and fuel injectors from the equation. If you don't have the appropriate adapter, you could try pinching the fuel return line.
If your pressure still drops to zero, it's probably the fuel pumps internal check valve.
Unless your also experiencing trouble starting, after your ranger has been sitting for an hour or so (common symptom to leaky injectors).
HTH
I recently bought a Bosch fuel pump and it was also made in China. Though its worked fine for the last 1500 miles
The “return less” fuel systems in the Ranger are interesting. Some are true one line systems and some have a return off the filter. I know at least with the ones that have a return off the filter have a fuel pressure regulator on the fuel sender assembly inside the tank. Theoretically replaceable.
My green Ranger has a no-name pump from the internets. It’s worked the past like 10 years. I couldn’t afford anything better when I got it.
Mom’s 02 Explorer I tried both a Delphi and a Carter from RA. One was DOA and the other lasted about a month. RA jerked us around and refused to warranty. That thing is a pisser to do a fuel pump in, you can’t even cut an access hatch and the tank is impossible to fully drop without a lift. I don’t remember what pump is currently in it.
My Choptop got an Airtex. Apparently the old pump was weak and I didn’t know it because a new pump made it run noticeably better. I only put a new pump in it because I was replacing the gas tank and didn’t want to mess with the crusty locking ring on the old tank.
Thanks to all for the information. The mention of a fuel pressure regulator had me look into that more. The pressure regulator for my Ranger is in the tank with the fuel pump. I finally found out why my fuel filter has two inlets. That is part of the fuel pressure regulator system and one of those inlets is actually an outlet. It seems the small line goes back to the pressure regulator and dumps the excess fuel back into the tank to keep the pressure where it is supposed to be. So, if the fuel pressure regulator is bad, it would probably not ever get up to proper pressure.
It looks like all the fuel pumps listed in Rack Auto for my Ranger have only one inlet and one outlet. I always thought it had two outlets. Apparently, the return line from the fuel filter that goes to the pressure regulator is considered an inlet. That makes sense now that I understand how it works.
So, it seems that one-way check valve in the fuel pump is most likely my problem. I will probably go with the Bosch pump. I checked again with Tasca, and they show the OEM fuel pump is discontinued.
I don't have the tool shown in my Ford Service Manual to remove the ring that locks the pump in place. I don't remember what I used the last time I changed the fuel pump. I am thinking a strap wrench would work. Any other suggestions?
Removing the ring is easy with a screwdriver and hammer. Getting it back on is a pain (if you don't have the special tool) but I found a video with a method (using vice grips) that worked perfectly for me. I'll find it and share it here.
I tried for two hours to beat the lock ring back on with a screwdriver and hammer to no avail. Had it on in seconds with the plier method lol
Those slip-on connections at the fuel filter are easy to remove.
I would check if your fuel pressure gauge kit has a slip-on adapter.
That way you could attach your pressure gauge to the inlet of the fuel-filter.
If pressure drops, then you have confirmed the fuel pumps internal check-valve has failed. If fuel pressure remains, your fuel pump is fine and your FPR should be replaced.
HTH
All the 98-01 tanks I’ve worked on had a plastic lock ring if I mind right and didn’t need anything special to do. I’ve used a hammer and screwdriver or a brass drift and a hammer on the older ones with the metal lock ring. Mom’s Explorer I had to use a chain wrench on the plastic lock ring because it was super tight. All of the steel tanks I’ve replaced have been replaced with plastic and those use screws and tabs to set the pump instead of twisting a lock ring in place
That vise grip trick looks good, but it may not work with a plastic locking ring. I will keep it in mind though.
HTH
Yes, it is a good idea to check to see if the check valve is my problem. My pressure tester does have and adapter that might work. It has a bulb on the end that may get in the way. I am going to change the filter anyway so I may be able to just cut the inlet tube off of the filter and test it with a hose attached to that. My kit has adapters for that.
The fuel pressure regulator is a part of the pump but is would still be a good idea to know what part failed.
I have a chain wrench and will keep handy in case I need it.
Here is the conclusion of this thread. I did a fuel pressure test from the line that come directly from the fuel pump when I replaced the fuel filter. I go the same results I got when I tested at the fuel pressure relief valve on the right fuel rail. Near 60 psi when ignition turned to 'on' and an immediate drop to zero. That confirms the check valve in the fuel pump is not working.
My next project is to replace the fuel pump.
