- Aug 6, 2007
- Age
- 78
- St Bruno, Quebec
 1991
It sounds like the pump is not running when the key is in the run position.
if your having this issue without any CEL. I would suspect fuel pressure. pull the vacuum line of the fuel pressure regulator and check that there is NO fuel in it. if that is ok i would do a fuel pressure test..............you put the fuel filter in the correct direction right?............
