- Dec 25, 2008
1991
Hey all, I have a 2004 Ranger 4.0, Auto. Lately have had this oscillating howl/hum coming from my front end which is indicative of a wheel bearing, along with a very slight vibration, but thought it could have been my tires so I've sort of let it go until I could further investigate. So I tore into it today and everything seemed tight and the spindle bearings seem fine, so I began playing around with the axles and noticed that the end of the CV axle closest to the differential on the passenger side wobbled a lot, so I think that is probably my problem. I replaced the seal on that side a couple years ago because it was leaking and slinging gear oil all over the place, should have replaced the bearing then. Just to note that I will be replacing the hub/spindle assemblies on both sides anyways because I am tired of tearing apart the front end of this truck. I am doing it all on one shot this time. The winters and salty roads in the mountains of PA aren't friendly to anything to begin with, but I feel like I am replacing axles, bearings and seals way too often.
Anyways, has anyone ever replaced the front axle shaft bearings (inner) and have any advice to offer? Any special tools? I will be tackling this next weekend hopefully. I've searched quite a bit and I don't see much online regarding these bearings. To my understanding, they do not carry much load since the rotating driveline assembly is basically designed to "float" and not carry much weight; only the weight of the axle and any rotational force associated so they do not go bad often.
