Classic: What size tires can I fit?
oniondip
10+ Year Member
I have a 2010 Ford Ranger with Ready lift keys, about 1/2 cranks and 2" ebay shackles (springtech). Right now I have 15" steel rims, black with the red/blue lip, pretty standard with 31x10.5" bfg mud-terrains. Just wondering if I bought an offset rim if I could fit 33x12.5"? And if anyone can think how much body lift before a 35x12.5" would fit. I do drive the truck in the woods, so flex will run me into clearance issues.
Thanks in advance.
no...
and no...
you wont fit anything more then a 31 without rubbing on flat ground. and a body lift will allow for 33's. you want 35's buy a dana 30 and a shop, cus your SASING!
but seriously, your talking big $$$$ and im assuming by bodylift, you dont wanna spend much. well without the cash 35's arent easy. 33's on the other hand, you could do. need atleast 3-4 inches of lift to clear PROPERLY.
if you maxed your t bars you can get away with a 285 75 16 which is (i think) a 32 11.50 15 but that extra inch to 33s will cause problems with out a body lift. 35s technically will fit with a 3in body lift and when i say technically i mean you can drive straight if the road aint too bumpy
Sweet, thanks guys. I guess I will just stick to my 31s for the time being, until I can afford a SAS, or better lift kit. Body lifts kind of make me cringe anyways.
