carburetor intake conversion
bugeater
20+ Year Member
This may have been address on another thread but i've come across a 302 out of 92 F-150 that is EFI and i'm wanting to switch it over to a carburetor. Will any intake for a 302 work or are the bolt patterns different from the older carbureted intakes to the newer EFI intakes?
Thanks for your help. I thought they would but didnt want to drop a bunch of money to find out that they didnt.
your dist will not work,you need a duratech,not efi dist.if roller cammed then you need an 85 stang model or replace gear to steel on any other year(pre 85) dist
Would that be Duraspark rather than Duratech?
Someone else found a use for GM parts on a Ford ? Seems like Duratech was a GM thing, or am I wrong?
no just got through working on one and had a brain fart.see what working on a gm will do to you.duraspark is correct
