BSI and Cluster draining my battery!!!
Conflict
5+ Year Member
sc
08 Tribute 4cyl automatic
4 fuses are always flowing
all fuses out I have 3-4 mA loss.
fuse 39 radio__150mA with bulb in circuit (analog meter). Pegged with no bulb. Meter only goes to 250mA.
fuse 14 radio buttons and display__130mA with or w/o bulb.
fuse 5 BSI__200mA with bulb, pegged without.
fuse 26 Cluster__170-190mA with bulb. Pegged without.
All in___digital meter shows a big rush (OL) then .9A & clicking noise from dash for 10 seconds then 1.4A & clicking for 10 more seconds then .7A steady & noise stops.
So I'll pull 39 and 14 for now. But what is a brake shift interlock and why is it flowing continuously? And what is clicking in the dash and how much should a turned off cluster pull?
It sounds like your battery saver relay is not functioning properly. That is part of the GEM or Body Control module. It has timers and delays turning off various circuits like radio and courtesy lights after you remove the key.
Sounds plausible. Where is it located? I don't have a schematic. Got a link to a free one?
I, personally don’t. Hopefully another member reading will have drawings that new. I’ll take a quick look in the tech library.
Event Coverage
TRS Merch
