- Sep 30, 2025
- Lewiston
- State - Country
- ID - USA
- Other
- '69 Bronco
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
Thanks for letting me join. I have been searching with google and facebook pages and have not found much info on swapping an AX15 into my son's '99 Ranger. I just swapped one into my '69 bronco and that is what got me thinking about swapping in an ax15 into his ranger when we do the 5.0 from an explorer, instead of using the m5od from a '97+ f150 4x4, which seems hard to find. I found an ax15 on marketplace with transfer case and drivelines for a pretty good deal. I like the idea of using the jeep's transfer case since it is small and should fit nicely between the frame and is manual shift and the ax15 is a game changer in my classic bronco.
Here's what I am wanting to know:
The ax15's shifter location is farther back than the typical m5od from an full size truck (pre'97) but by how much? And would it be worth it?
The '97+ m5od 4wd w/ V6 is hard to find and I don't like the idea of using the full-time 4406 transfer case. Unless it comes in a part time variety, that would be great, but again, hard to find.
If I used the transfer case from a full size, how much of the frame to you have to notch to make it fit?
Thanks for any input.
