Hey Guys,
Did a search, but couldn't find a specific answer to my dilemma.
I've got the P0153 code & I would like to go ahead and change out the oxygen sensor asap. My gas mileage is atrocious! Like less than 12mpg [emoji15]
I don't know if this code was hidden before I bought the car recently. It if this halogens as a result of using e85 gas for the 1st in maybe a very long time? Maybe the fuel cleaned deposits & dirtied the sensor?
Either way, need changed out quick. I'm going to go with the Bosch sensor.
Just not sure which one is correct. I believe from what I've gathered here, the sensor in question pertaining to this code should be the driver side, closest to manifold?
On the Bosch website (picture attached)
I've got two sensors that are upstream. Which one should I use?
Amazon link: Bosch 15716 Oxygen Sensor, Original Equipment (Ford, Jaguar, Lincoln, Mazda, Mercury) https://www.amazon.com/dp/B000BZI4JI/?tag=959media-20
Bosch 15717 Oxygen Sensor, Original Equipment (Ford, Jauar, Lincoln, Mazda, Mercury) https://www.amazon.com/dp/B000BZI4JS/?tag=959media-20
Sent from my SM-N950U using Tapatalk
