A/C Delete Belt Requirements
kdenmcfish
Forum Member
Denver, CO
CO - USA
Vehicle
Drive
2.9 V6
Hi All,
It was 103°F locally yesterday and unfortunately my A/C compressor is shot. I have confirmed 12V power to the unit and am reading OL at the compressor itself... also no clutch engagement when jumped from the battery - RIP.
The truck still has an R12 system, and an R134A conversion isn't a priority over the other work I have planned for the truck. It's going to have to wait till next summer.
That being said, I am thinking about removing the R12 components to free up some room, as next summer I would prefer to install a whole new setup. The system is still charged, so I will need to have it evacuated by a shop, anybody know where I could get this done for free?
My other question is regarding the A/C compressor drive belt. Ideally, I would remove the compressor entirely and delete the associated drive belt as well, but I am curious if this drive belt is needed to provide adequate power/support to the water pump? All three drive belts (PS, A/C, alternator) on the engine run through the crankshaft and water pump, and then branch off to their respective systems. If I was to remove this drive belt, would it have a negative effect on my water pump/other belts (additional strain)?
As long as one of them connects crankshaft to water pump you should be fine.
My 98 used to have a sticker on the radiator support that showed both with ac, and without, belt routing.
Just pull the belt off it and roll
