4.0 SOHC won't start after top timing chain tensioner change
Texan209
Forum Member
Austin, Tx
TX - USA
Vehicle
Drive
2WD
So... I may have gotten myself in too deep but I thought I heard the infamous chain slap on startup the other day so I decided it was finally time to change timing chain tensioners. I'm very much a shade-tree mechanic, but I recently replaced my thermostat housing, so it's a pretty similar process to get to the tensioner. Unfortunately, everything is back together and the truck won't start.
I installed it dry but cranked the engine in "clear flooded engine" mode for several seconds a couple of times to build oil pressure before starting.
When it came time to turn the key, I got a few pops like it was trying to start, but it sounded pretty rough so I stopped cranking.
I have yet to hook up an OBDII to it, but I've rechecked the spark plug wires, vacuum lines and electrical connections, and it all looks correct. I'll re-check everything a third time with fresh eyes, but I'm operating on the assumption that it's all back together correctly.
This brings me to the question of - is it realistic that the timing moved on me during the switch? All I did was unscrew one tensioner (top drivers side) and replace it - truck didn't move or do anything that I would expect to change the timing, but here we are.
Has anyone heard of this before, or had a similar experience? From the research I did intially, it sounded like a pretty straightforward piece of maintenance.
You only did the front tensioner? If so maybe the passenger rear was the one that went out and that allowed the chain to skip a tooth? Hopefully not and you get it figured out soon.
I wouldn't think removing a tensioner and replacing it without running the engine would let it jump time.
I would put a ratchet on the crank bolt and rotate the engine by hand a few good revolutions to make sure nothings making contact that shouldn't be. Beyond that I'm not sure as I'm new to this as well but I'm sure some others will stop by to offer advice. Good luck sir!
One thing I was wondering about when doing my engine is how long it takes the new tensioners to build pressure because spinning my engine by hand with new tensioners, the tensioners don't have enough pressure (obviously with no oil in them) to keep tension on the guides and the guides move back and forth with the slack in the chain. The word is that they don't need to be primed though.
Makes me nervous when I go to "prime" my engine in a few days with the fuel pump relay out.
Did it run before you worked on it?
I think they can only jump time if the guides are busted up.
The tensioners go bad... let's the guides destruct... planets align... jumps time and seriously breaks stuff.
I did tensioners... didn't prime them... disabled fuel... crank a few times. Enable fuel... fire it up.
Event Coverage
TRS Merch
