33x12.50s
myranger26105
vienna, west virginia
i am running 265/75/16s right now and was going to goto 33s with some new wheels when i get enough saved up i know i will need a BL i have 4.0 5speed with 4.10s would it be a big difference going up in that lil of a size with performance and driveability and do they make a 33x11.50 can really find anything that size? would prefer 11.50
a 265 measures about 32"......your new 33" tire will be at most 33" tall, probably 1/4"-1/2" less.....you should be fine. i doubt you need a BL. the gears will be fine too.....as for the tires, i'm sure someone makes an 11.50, i've seen 10.50's and of course 12.50's
i have found alot of 12.50 and alot of 10.50s i have always seen to fit 33s without rubbing you needed a body lift
i just noticed you wanted to get new wheels too, if you find some with proper backspacing, you can keep them from rubbing. also depends on how wide of a tire you get and how wide the wheel is.
are the 265's crammed in there? are they rubbing?
