205/65/15 or 215/65/15
deerman2701
15+ Year Member
What tire would be better for my little 4 cylinder? Right now the 235/75/15 are making my engine struggle a lot. mainly at high speeds on the highway! thanks everyone! just want to figure out what i should order!
http://www.therangerstation.com/tech_library/Metric_To_Inch_Tires.html
http://www.therangerstation.com/tech_library/Speedometer_Change_From_Tires.html
Those two calculator links should help you decide, after you check the door label for the original tire size. FWIW, I'd also consider a replacement axle, 4.10 with limited slip would spin the tires you have now quite well.
This link will decode your axle code on the door label (determine ratio installed now): http://www.therangerstation.com/tech_library/Axles.html
Depending on your gears I would go with the 205/65/15 tire, I just put them in place of the original 225/70/14 on my 98 when i upgraded to 15", I couldn't be happier with them i bought dunlops been great I have a 2.5 5speed with 3.55 gears
Im gonna take my chances with the 205/65/15...
Hopefully they will fit on my 15x7 rims!
