2002 3.0 discharging steady 0.2 A
mud
5+ Year Member
East Jesus, NM
Hi everyone, my 2002 3.0 V6 2WD has been discharging at what seems to be a steady 0.2 A. This may have have started a few weeks ago when I changed the oil and accidentally briefly shorted it between the starter motor and the oil filter. Or maybe it’s always been like this. 🤷‍♂️
After changing the oil, I started the truck, ran it, and checked the oil. All good. Then the truck sat for 3 weeks before I tried to start it (which is unusual.) Nothing. 4 volts. The interstate battery was 1 year old. Tried charging it, but neither of my chargers would even initiate a charge, probably because the voltage was too low. Battery was 0.5 volts a few days later.
Now I have a new battery (12.59v) and checked the current before totally committing to bolting it in. It’s pulling a steady 0.2 amps (2.5 watts), which I’m not sure is normal or not. Seems low, but also higher than I expected. Key off, doors closed. No accessories or dome light running. Just the computer(s) and maybe radio, which may require something for its memory.
What’s a normal standby current?
In the meantime, I guess I’ll be pulling fuses and taking measurements.
Ok, I’m gonna chalk this up as a false alarm. I decided to rake some leaves and check back later, and after 1 hour, it was down to about 7 - 10 milliamps. It must’ve had a higher draw during some restart period.
03 should have a battery saver function that kicks in after 10 minutes or so...
Yeah... you can only test for current draw after after battery run down protection has initiated.
Normal draw on today's vehicles is 50 or 60 mA.
