1st gen Ranger rustproofing tips and tricks
MISWFL
Forum Member
Florida
Any specific areas that need extra attention? Best products for home applications? California truck will be used in Michigan during the winter a bit.
Drip rails tend to rust pretty commonly on these trucks, luckily they're hidden from sight if they begin to rust so a little sanding and a shot of primer and no one knows the difference.
Of course its hard to tell how much preventative maintenance will do on a steel body truck in the north
Oil/wax based rustproofing is best. Get the whole underside sprayed. Down inside the doors too. Cab corners, up in the wheel arches. DIY, probably go with Fluid Film. May need to recoat every year if you’re in the rust belt in winter.
Do NOT, not ever, not in a million years, go with a rubberized or asphalt based undercoat. Unless you want rot to move at the speed of a forest fire under a 30 mph wind.
Where are those? Lower body pinch welds, like the bottom of the rockers?
I fluid film pretty much everything. Inside the door drains, inside the fenders, inside the bed supports. Make sure you clean out the door drains and bed supports first so you don't trap a bunch of crap. I use about 3 cans to cover everything
Theyre the small pieces that overhang off the roof over the doors on your truck
RIP to another first gen.
You will not stop rust.
You will not completely prevent rust, the metallurgy is not there.
Rust will form like a cancer, and eventually return the truck to the earth.
The only hope is to not use the truck when there is salt, however slight, on the roads. This is why I own a GM, for November thru April driving.
Fluids and oils and sprays will slow the progress, but once rust starts, it never stops, and it never sleeps.
I hope that's not true. I've heard people use used oil motor & gear oil and spray the undercarriage every year with good results. There's also some cosmoline stuff you can spray as well. Do you mean because the metal wasn't galvanized when it was made?
I haven't seen the truck yet or even any other pics of the outside, but I doubt it's a very nice truck. I'd prefer an extra/king/super cab because I've got long legs and like to sit far back. I'm not into 4WDs because I'm not into off road driving. The only use for me would be a bit of winter driving in Michigan. Another issue is even fixed up, auto or manual transmission, it's not worth much. Probably not enough to justify my cost to get a bonded title, and get it running. Let alone to sell and buy something else either AWD or 4WD. Just the cost to get a paint job is probably more than it's worth as an automatic. I already have an old Datsun king cab that's 2WD. Seems like the Ranger would be a good beater truck, as the Datsun isn't very practical for hauling or towing. A 1983 Ranger would be ideal because of Michigan's registration scheme. 1983 was the last year that registration goes by weight vs MSRP.
I hope that's not true. I've heard people use oil motor and gear oil and spray the undercarriage every year with good results. There's also some cosmoline stuff you can spray as well. Do you mean because the metal wasn't galvanized when it was made?
Some not all of the truck is galvanized. Galvanizing is also a coating, it only slows rust. Old galvanized windmills, grain bins and roof sheeting all rust... and they are not even in the salt being pummeled by road debris.
