- Nov 9, 2017
- Automatic
I have a 98 ranger 3.0 FF engine code U and a 2000 3.0 engine code V both automatics 2 WD same two trucks options, the 98 FF already had engine and trans and all wiring removed from the engine compartment except PCM, i got absolutely nothing in eng comp except Heater A/C housing, I took everything out of eng comp,Engine trans all wiring vac lines A/C condenser, My question is can i take the 3.0 and trans out of the 2000 and put it including engine wiring harness and put it in the 98 FF, Can i use the wiring and all from the 2000,I think i have to change the injectors and FF PCM from the 98, the PCM is all i have no injectors, Andhow do you tell the difference between FF injectors and gas injectors by looking at them, are FF inj always GREEN ? is it a fact that all 3.0 and 4.0 v.6s made in 1998 are FF, none were made non Flex is that true, any help would be greatly appreciated,thank you very much !
