1994 Windshield and rear window compatibility?
New York
Hello, I have a 1994 Ranger extended cab with a cracked windshield and broken rear window, I was just wondering if the windshield and rear window from a 2006 Ranger extended cab would fit onto my 94?
I am pretty sure the windshield is the same from at least '93 and newer. Unfortunately, the rear window is different between regular and extended cab.
There were two rear windows over the whole span of '83-11 (well 3 if you want to get technical but it's just the added 2 studs on the last couple years)
Regular cab rear windows are the same from '83-97
extended cab rear windows are the same from '86 through '11 which is also the same as '98 and newer regular cab rear windows
