The $600 1988 Ranger project... a twin turbo big block build.
Couple of pics
Pulled out a tape measure today and yeah..... the intercooler has to move forward a little because the electric water pump will try to occupy a bit of the same space.
Just got back from doing Rocky Mountain Race Week with my youngest son in his project car. We had a great week. If you are interested in reading my recap, click on the link to Bangshift. There is also a quick recap video.
Raceweek wrap up and I moved the intercooler forward to gain water pump clearance.
I've been stalled for a while thinking about how to do the hot side and how to fit the wastegates into it all. Just as a recap, the hotside will simply be some log headers that wiggle up and feed the turbos. It's fairly tight in there and I eyeballed several different places to mount them. Then it clicked. They can be mounted straight off the front of the log pipe and the turbo feed can peel off the log as needed. This will position the top of the wg's pointing forward toward the core support, This should be a very stable position and will allow the dump to go right out toward the ground.
Fabrication of the hot side begins! The 3d printed die that I made to form the oval pipes worked amazingly good.
More and more reasons to get a 3d printer...
It's been stupid hot so my desire to be in the shop has been low. Still, I took a few minutes and tacked on the waste gates. Stuff is tight, but is fitting together like I want it to.
Getting a pipe out of #8 around the steering shaft was kicking my butt. I decided to leave it alone for a few days and try to come up with a better solution than I have so far.
I also made the executive decision to put carpet in this thing. Kit is ordered. I was going to put a vinyl floor mat, but felt it was just going to look dirty all the time..
