New member from Michigan Bronco ii
South Lyon
MI - USA
Vehicle
Ford Bronco II
Drive
Here is "Lil Bucky" my 1987 Ford Bronco ii. Eddie Bauer interior, 5sp, electronic 4x4.
After sitting for 20 years I replaced the fuel tank, sending unit, heater core, striker bushings. Truck has 84k miles and is super clean all original California truck.
What gear ratio does this have?
And does anyone have a XLS front air damp? My original one was removed/damaged.
Is there any big Ranger/Bronco ii meetups is Michigan?
  • New member from Michigan Bronco ii
Hey MP! Lots of BII owners here. One of them will be along shortly with your answer. I used to own BII back in the mid 80s, but unfortunately cannot help with an answer to your query.
Hang tight and thanks for posting pics.
I'm up in the Port Huron area
Welcome to TRS.
EDIT: I'll take a WAG and say 3.73 or 4.10
Welcome to the site. Does it still have the door sticker? most general info can be found on that.
Still there but I can’t read it
Sweet Rig 😎
You might want to compare the numbers from the metal tag on the rear diff cover.
Any numbers behind the brake line (in your pic)?
My 90 B2 4x4 5spd has 3.73
What year did the B2s change to 5spd?
Welcome to the brotherhood...cheers 🍻
On faded door stickers, I've had some luck in taking digital pics with various lighting, and then getting them onto a PC, where you can zoom in and play with contrast and brightness of the images.
If you can get a good image that way, a print of it would be a good addition to your paper files package for the truck.
And I'm not sure, but I think that maybe a higher-option Marti report might include an image of the door sticker.
Thanks for the help, was able to look at the front diff tag and found out it’s a 3.45 :(
Was hoping for something around 4.10s but I guess I get fuel economy on the highway.
