Where to find a 98 3L y-pipe
Tsestak45
5+ Year Member
Philadelphia
So I'm putting another brand new remanufactured motor in my truck because the first company's (whom I'm not allowed to mention their name anymore because of the lawsuit we settled) first engine made it 900 miles, second engine 3,000 miles, and the third and final engine 17,000 miles before a camshaft bearing exploded. Anyway my exhaust forever had a week where the wide pipe met them around folds because my original one was all pitted and rusted and I bought a fabricated one on eBay and the fabricator had the pipe coming too far up into the ball socket and so the manifold was hitting the lip and not sealing all the way. So I would preferably like to buy a brand new one from a reputable company but as far as I can tell nobody sells brand new y pipes for 98 3L. From all the pictures I seen it looks like the 4L y-pipe is identical but I've never seen one in person. I'm not talking about the ones with the cats built into it I'm talking about just the straight pipe one with the two O2 ports. Does anyone know if their interchangeable? And please don't give me all the same stupid answers of "I would just go to a U-Pull-It and get one" or "did you check eBay and Craigslis?" Or "just go have one fabricated at an exhaust shop". If I wanted to do any of those options I would have. I would like to buy a brand new one never been touched or used before.
According to Walker, 98 had converters in the y-pipe. I'd bet it was more likely a transition year.
Unfortunately all earlier 3.0 y-pipe seem to be unavailable. AP/Eastern and Walker both make 4.0 y-pipes but say they don't fit the 3.0 Some of them are listed on E-Bay for 3.0/4.0, but if you look at the list of compatible vehicles it shows 97 Ford Ranger 3.0 (with 4.0 engine only). LOL
The one 3.0 I remember working on had more an H shape than Y.
Wish I could be more help. Maybe buy one for the 4.0 and modify as/if needed?
I'm in the same boat regarding the Y pipe. I desperately want to pull my transmission to throw in a rear main seal but I know the Y pipe flanges will not survive. Pipes and cats are in decent shape, but the flanges have lost half their thickness and fused in rust with its mating flange.
AP/Eastern has the cheaper EPA compliant Y pipe for $309 that I might just buy and use as a jig.
  • Where to find a 98 3L y-pipe
Yes see my y pipe doesn't have the cats on it they're separate after it connects at the bottom. All the pictures I see that say 98 3.0L/4.0L look like the exact correct size and shape for mine so I think I'm just going to buy that and see if it fits and then if it doesn't make them return it for free and say that they listed it incorrectly because I don't have any other choice really
been in the same situation, had to go with used.
those are not stupid answers.
that is the state of reality in the readily available market..
the best way to get a brand new that has never been touched before y pipe.......you know...new one that works better than anything that ever left a ford assembly line, is to have a competent exhaust shop make one.
you will get that, and depending on material....potentially cheaper then anything you will buy pre made. and it will be done a an hour or so.
the absurdity in your statement is its own hell.
that said, there is definitely a NOS 3.0 y pipe out there somewhere....from free to 300 bux.
good luck finding it in an expedient manner of time verses money.
Aftermarket Y pipes are the same for 3.0 and 4.0. They're both 60deg V6s with "close enough I can't find a difference" manifold locations. Ford might've made the shape slightly different or something but in any case the aftermarket has figured out how to do it with one pipe. This is why you "can't find" 3.0 Y pipes. Nobody is making one that only fits a 3.0
Far beyond my experience and knowledge, but I had a thought. Can’t you combine some of this advice?
Buy the closest Y pipe you can find, where the flanges will bolt up in the front, and then cut it at some point and re-weld it once installed. If it’s a close fit, you may not even have to completely cut it, you may be able to slot it so you can bend it to the correct configuration, and then just weld up the slot. Yes/no?
Again, just a thought
this is true to an extent, they can make the manifold dump in the same spot on both engines. but it is not a thing across the fleet.
at some point this is the case iirc they are modularized but it is in the 2ks, but i do not remember what the years are. there is earlier and later.
2.9 and 4.0 are workable as well.
yeah. its just too easy.
my 2000 3.0 4x4 auto has the style without cats. it was manufactured late in the model year.
My 4.0 still has a y-pipe spec-ed for the original 2.9.
I wouldn't even weld it back together. I'd get it so the pipes but up against each other and then use a band clamps. A lot of FWD car headers come as two pieces that you band clamp together because that's what works best for ease of fitment and it gives the pipe something other than a solid joint there so it can slip a little somewhere to account for movement and expansion. The band clamp is cheap if it ever needs to be replaced.
