1984 ford ranger 4x4 2.8v6 spark issues
I purchased the ebay duraspark late last year, that shows still available today. Install went very easy once I had most surrounding parts removed for a leaky intake gasket. After changing valve seals, and cleaning and painting, put it all back together and its running better than it ever has!
  • 1984 ford ranger 4x4 2.8v6 spark issues
Thanks, i have fixed the issue, turns out it was just the tfi module in the back of the distributor, 20 bucks is better than 200, i'm going to run with it until something brakes, thanks for all the info, nw i got to fix the 100 vacuum lines, and tun the carb
