Anyone Upgraded to LED Headlights for the First Gens?
I have spent all day working on a tech article discussing the different ways to add LED headlights, and what I quickly realized is that all of these companies are full of crap when they list the lumen ratings for their LED bulbs. The only company that I have found that rates their lights truthfully is LASFIT.
For an LED, Lumens = Watts × Luminous Efficacy (lm/W)
Standard LED: ~80–100 lm/W (Example: 50W x 100lm/W = 5,000 Lumens)
High-Efficiency LED: 110–150+ lm/W (Example: 50W x 150lm/W = 7,500 Lumens)
In the ad below, it's not possible for a 40W light (or dual 40W lights) to put out 46,000 Lumens. You'd need 460 watts to put out 46,000 Lumens. Even a really highly efficient LED would still require 306 Watts. Two 153-watt High-Efficiency LED's might do it.
I saw ratings for 9004 LED bulbs that ranged from 30,000 Lumens to 70,000 Lumens. 🤦‍♂️:shok:
When I did mine a couple years ago people were still rocking candlepower ratings too, that may have been me cross shopping vs halogens at the time. It was really annoying trying to compare things.
That seems to be the case with a lot of things. I run R/C crawlers, and you have to look past the hardcore brand-loyal individuals, paid ads, and marketing documentation. You start to see that, while a lot of companies claim to have an edge, really they're just repackaging batteries, or buying from the same suppliers. All their C rating claims are false, with one or two outliers.
When looking at aftermarket stuff you have to sit back and think "this company isn't big enough to actually make this part themselves"
I really like some of the 6054 LED Headlights that are available. You could rebuild a 1st Gen ad give it a modern look, but I also like the idea of using a glass housing that looks like the original headlights but using an LED bulb in it to keep the retro look.
Finally finished what I was working on for anyone interested:
I will also add it might be time to do some small electrical projects/upgrades.
I'm running the original alternator and external voltage regulator. I would like to upgrade that.
I do think it will likely be worth while to wire in relays for the lights. I noticed when I turned the heater fan on high I could see the lights dim ever so slightly.
It will be worthwhile, but you may as well just put in a whole new harness that runs from the battery to the headlights with the new relays. Also, I believe a headlight harness can also take some of the strain off of the headlight switch.
Plastic lenses will yellow on you over time no matter what. So unless you like replacing them or doing the whole sanding and polishing thing, it makes sense to spend the money up front and buy the glass H4 housings. Plus the glass lens design is far superior to any LED housing on the market. Most of the sealed LED housing also take on moisture over time.
The only true downside to the glass lenses is that they will very likely crack if a rock hits them- it happens.
Yep, and there used to be aftermarket mesh screens to protect from that. Just be in front of the pack and not have to worry about it...😁
@ford4wd08
Changing from halogen bulbs to LED quantifies a $137 citation where I reside; I was on the fence regarding going to LED's, so I looked deeper:
1) I need ice and snow to melt
2) I avoid all circumstances which cause me to look the Sheriff in the eye
SOLUTION
I built battery/relay harness controlled by the original OEM light switch, used 14g multi-strand oxygen free copper (OFC) wire with the GS Power housings, the Hellas we're my #2 choice, with Hella H4's from Summit.
Resulting in a tremendous improvement in light, looks stock and is 100% legal. I am looking into a more stable bulb product, as one of the set of bulbs died in only 3 years 😪
Not headlights. (Jim's article is pretty good.) But has anybody tried some of the LasFit H3 bulbs in a KC Daylighter housing? That 130w each halogen is kinda rough for current draw.
I have long wished there was alternative to LED converting them aside from KC's kit...
I think they'd put out the same amount of light, but use less watts.
The best-case scenario for a halogen bulb is 24lm/W which would be 2400 lumens per bulb.
Lasfit's H3 bulbs are 20W and put out 2,000 lumens per bulb.
You could end up putting out the same amount of light but consuming 40W instead of 200W.
I think you should do it in the name of research. :popcorn:
Circling back to this.
Hands down best upgrade I have done to my B2 for just driving has been the Hella light upgrade. For the money and as simple as it is, I highly advise it for anyone driving a first gen RBV at night! I still can't believe the difference!
